SciFi 1/60th Hellbringer [DONE]
Pagina 1 van 8 12345 ... LaatsteLaatste
Weergegeven resultaten: 1 t/m 15 van 106
Discussie: 1/60th Hellbringer [DONE]
  1. #1
    Standaard 1/60th Hellbringer [DONE]
    Een volgende Battletechkit die aan het roepen is om gemaakt te worden : de Hellbringer.
    Fluffwise
    The Hellbringer is often deployed by Clan Jade Falcon, which favors the design for its immense offensive potential. Earning the codename Loki by a minor AFFC officer, who declared each of the Hellbringer's various versions as an "utterly mad configuration", the 'Mech does at first glance appear to be highly unusual, mounting a spread of weapons, anti-personnel equipment and electronics. The Hellbringer utilizes a standard internal structure, and has decent mobility, with a top speed of 86.4 km/h. Though it has vast firepower at its disposal, the design is not particularly durable, mounting a mere eight tons of Standard armor, and the Hellbringer is not particularly suitable for defensive situations or extended engagements.
    Armament
    Though the sheer amount of equipment is greatly confusing, comparing the 'Mech to those at the time of the Exodus, the Hellbringer Prime bears similarities in design and appearance to the classic Warhammer. The primary weapons are indeed a pair of ER PPCs. As the Hellbringer draws closer to its target, it can bring its smaller and less heat-intensive short-range weapons to bear on the target, with three ER Medium Lasers and a Streak SRM-6 missile rack. The 'Mech is more than capable of handling infantry, with a pair of Machine Guns and two Anti-Personnel Pods on each leg. An advanced Targeting Computer gives the energy weapons lethal accuracy, and an Active Probe and ECM Suite help to minimize any tactical advantage the enemy may have. To help increase battle longevity, the Hellbringer also carries an Anti-Missile System.
    Alternate Configurations
    Alt. Config. A - The Hellbringer A, though apparently a long-range configuration, does have some unusual equipment. A set of two ER Large Lasers and an Ultra AC/5 serve as primary weapons, and are supported by a LRM-20 rack. The 'Mech also carries a Narc Missile Beacon to increase missile accuracy, probably intended for nearby fire-support units. At close ranges, the 'Mech can defend itself with an ER Medium Laser and also has two Machine Guns and an Active Probe for point defense. BV (1.0) = 1,651
    Alt. Config. B - With a high damage profile at long and short range, the Hellbringer B does not utilize energy weapons as much, and so has few issues with heat buildup. A powerful Gauss Rifle and LB 5-X AC allow the 'Mech to ravage both armor and critical systems, with the Gauss Rifle's powerful slug and the LB 5-X's fragmenting shot. At closer ranges, the 'Mech has two SRM-6 racks slaved to Artemis IV fire control systems for greater accuracy, with an ER Small Laser as a backup weapon. BV (1.0) = 1,454
    Alt. Config. C - A powerful brawler, the Hellbringer C's only long-range weapon is an ER Large Laser. The 'Mech also makes use of the recently developed ATM-6 launcher, which can perform similarly to LRMs, MRMs or SRMs, depending on the ammunition loaded. The Hellbringer C carries a devastating LB 20-X AC as its knockout weapon, able to quickly shred through armor with slug ammo or damage internal components extensively with a fragmenting cluster shot. A pair of ER Medium Lasers and a ER Small Laser act as backup weapons. BV (1.0) = 1,698
    Alt. Config. D - This variant is a vicious infantry hunter. It has four Plasma Cannons that are capable of dealing immense damage to conventional troops. Four B-Pods provide defense against battle armor, while four Medium Pulse Lasers provide accurate damage potential against hardened targets. A head-mounted Micro Pulse Laser provides added firepower against unarmored infantry.
    Alt. Config. E - This support variant uses a pair of ER Large Lasers for consistent damage. An LRM 10 supports them, while a Hyper-Assault Gauss Rifle 20 with twelve shots provides a high-damage threat.
    Alt. Config. H - The Hellbringer H utilizes new Heavy Laser technology for its short-range arsenal. The long-range weapons of the 'Mech resemble those of the A configuration: the Ultra AC/5 is retained, though the ER Large Laser is upgraded to an ER PPC and the LRM-20 is downgraded to a LRM-15. For close range combat, the 'Mech has a powerful Heavy Large Laser and an array of four Heavy Small Lasers. The defensive equipment is the same as the A configuration, two Machine Guns, two Anti-Personnel Pods and an Active Probe.
    Zo ziet deze dame er uit :
    Het model
    Zoals de Kit Fox komt deze van Battlemech Club.
    De kit zelf is accuraat aan de bovenstaande Line Art uit de 3050 TRO. Er is echter een update van deze tekening in de 3050 TRO Upgrade, met veel mooier en realistischer lay out. Deze aanpassingen zal ik dan ook uitvoeren.
    Ik zal dadelijk wat eerste picca's plaatsen met de onderdelen
    Mijn blog :http://jadefalconguard.wordpress.com/
    My Wallet is curled up in a corner, scared, lonely and wondering when the hurting will stop....
    the Wallets feels dirty, unkept fingers fondle it at all of his secret places...
    The screaming starts.......
  2. #2
    Standaard
    ziet er een vreed beestje uit
    wordt dit in speciale kleuren geverfd
    grtz
    huge
  3. #3
    Standaard
    Ben zeer benieuwd naar dit beestje. Ik doe wel niets met clubs. Maar het wel weer een gaaf beestje.
    Je maakt mij toch wel weer helemaal blij hiermee. Ik denk dat ik ook maar eens zo'n beestje ga knutselen weer. Nu zit ik toch steeds te wachten met het drogen van mijn scheepje.
  4. #4
    Standaard
    Ik heb mijn eigen TRO even langs de scanner laten passeren om de lijntekening te kunnen plaatsen. Zo ziet deze dame er tegenwoordig uit. Meer textuur en conform de wapenuitrusting vand e Prime variant :
    Zoals je kan zien zal er heel wat werk zijn, want tal van details zijn hier niet aanwezig. Zoals gezegd, deze Hellbringer is gemaakt naar de originele TRO 3050 en die heeft deze details niet
    Eerste stuk : torso onderdelen :
    Tweede stuk : benen:
    Derde zakje : armen :
    Inderdaad, deze kits worden geleverd in hersluitbare diepvrieszakken, zonder handleiding of iets Een rasechte garagekit dus
    Sommige van deze stukken zullen aangekleed worden volgens de pentekening van de 3050 upgrade en andere uit de losse pols als het ware. Een klein voorbeeldje :
    De neus van de Hellbringer lijkt me langs de zijkanten nogal leeg.
    Ik zou natuurlijk kunnen beginnen met paneellijnen te trekken ed, maar vond het logischer dat er een aantal inspectiepanelen aanwezig zijn daar.
    Dus duiken we in de verzameling van de onthaalmoeder in mijn huis en vissen daar de doos met 'bling bling' letters uit. We nemen de letter D en halen de vulling van het buikje er uit en....
    Presto ....... een mooi gevormd inspectiepaneel :
    Voor de niet onthaalmoeders onder ons, de 'Bling Bling' letters zijn simpelweg felgekleurde letters in plastiek die je o.a. in de 'fun' kan kopen. Kinderen spelen er graag mee om namen en woorden te vormen op papier.
    We doen juist hetzelfde met de voorste 'ammodoors' op de torso's volgens de pentekening. Deze maal gebruiken we de letters 'O' voor de panelen :
    Die we daarna wat opvullen met putty en gelijk schuren.
    Met behulp van een donorkit (in dit geval een M113 op 1/35ste) beginnen we de anders kale torsodelen aan te kleden.
    Vooraan kun je de tw<ee letters 'O' zien, op de zijkant eens tukje van een paneel van de M113 en de steun achteraan is voor het searchlight te bevestigen.
    Voila, dit was'm voor nu.
    tot de volgende
  5. #5
    Standaard
    @ Huge, ben d'er nog niet helemaal uit, maar een ding is zeker, het wordt een mech van de Jade Falcon Guards
    @ Rik : die club is gewoon de naam van drie vrienden die deze kits zelf maken. Je moet echt eens kijken naar hun 'on the bench' voor andere gave modellen...schitterende vooruitzichten. Je hebt een mooie lading onderweg, dus laat maar komen.
    Voor de geïnteresseerde, van deze Hellbringer (Loki voor de Inner Sphere mannen) bestaat er een volledig opengewerkt diagram in poster (die ik uiteraard heb ). Die ziet er zo uit :
    Mecha Image Of The Day Archives Battletech: Loki technical diagram[/SIZE]
    Laatst gewijzigd door Jadefalconguard; 06-06-09 om 21:36
  6. #6
    Standaard
    Ik ken ze, ze maken idd mooie mechies zoals wij dat hier zeggen. Alleen jammer dat ze niet vertellen hoe ze het een en ander doen. Verder zijn ze best kostbaar zie ik.
    Ik moet zelf weer aan een makkelijkere beginnen. Het schilderen is echt roestig geworden bij mij. Jammer genoeg.
  7. #7
    Goede topic beantwoorder dancooper's schermafbeelding
    Geregistreerd
    15-12-07
    2.001
    Standaard
    Citaat Oorspronkelijk geplaatst door modelengeneer Bekijk bericht
    Hehe, ideaal om zwaar te verweren, zou ik zo denken
    Jade, dat ziet er een heel interessant projekt uit, ik denk dat, indien deze kits langshier in de winkels zouden liggen, ze best zel goed verkocht zouden geraken.
    In m'n jonge jeugdjaren heb ik destijds ook nog die Revell Battlemechs gemaakt, spijtig dat ze tegenwoordig nog amper te vinden zijn.
    Ook heb ik er nog eens even over nagedacht om zelf eens zoiets uit m'n mouw te schudden, maar ik denk niet dat ik daar de capaciteiten voor zou hebben.
    Alvast veel succes gewenst.
    Dany
    Op de werkbank :
    Huidige actieve bouw : Central Pacific N°60
    In de koelkast : Cn2t "Las"
  8. #8
    Standaard
    Rik, er komt een mooie lading af...dus tijd zat om te oefenen
    Dan, gewoon even proberen zou ik zeggen... veel moeilijker dan een andere kit is het niet.
    Juist ter info, kreeg deze avond het volgende mailtje binnen :
    Hey Geert,
    I posted your links on the battlemechclub website and also on our blog.
    Tim
    Modelbouw1.be gaat internationaal
  9. #9
    Standaard
    Jawel dit wordt weer een project om van te smullen
    Groeten, Pascal
  10. #10
    Geregistreerd
    15-12-07
    2.001
    Standaard
    [QUOTE=Jadefalconguard;41909]
    QUOTE]
    Haha, je spreekt hier wel tegen den Dany heh, da gastje die aan van alles en nog wat begint, en die er in de laatste 9 jaar nooit ook maar 1 keer in geslaagd is iets af te werken /cry
    Dany
    Op de werkbank :
  11. #11
    Standaard
    Hey Geert,
    Tim
    Dat is mooi man.
    Maare, verder ben ik dan ook wel benieuwd naar de vorderingen van deze mech.
  12. #12
    Standaard
    Hier zijn we dan ook met wat vorderingen. Na het leggen van een vals plafond het fijnere werk
    Tijd om de details (of in dit geval het ontbreken van details) aan te pakken. Hiervoor gebruiken we deze overschot van een zonnewering in plastiek, beter gekend als 'lamellen' in de volksmond
    Onderwerp van de update is het linkertorso :
    Als je kijkt naar de tweede pentekening zie je onderaan het torso een aantal vents zitten.
    Deze worden op een uitgesneden stukje lamel overgezet :
    Maar aangezien een dremel nogal ruw is om dit uit te snijden volgde er al gauw een tweede en derde exemplaar
    Uiteindelijk opnieuw begonnen :
    en deze uitgesneden met de X-acto
    Daarna de torsohelft aangepakt en na het uitdremelen van de ventilatieruimte deze verbonden met verband om een rooster te simuleren :
    Eenmaal dit opgedroogd kon het nieuwe donorstuk worden geplaatst :
    De volgende stap zijn de 'X'-vormen op de armorpanels. Deze zullen nog wat anders zijn vrees ik, maar dat zien we dan later.
    Tot de volgende
  13. #13
    Standaard
    Ben benieuwd naar het vervolg
  14. #14
    Standaard
    Ziet er mooi uit, idd kun je dit spul toch het beste doormiddel van snijden uitsnijden. Wat ik altijd doe is gaatjes boren binnen de lijnen. Dan deze openen. Vandaaruit met een scalpel gewoon de lijnen trekken tot het moment dat ik op de juiste lijn ben. Dan schuren en klaar.
    Verder zou je onder de vents niet eerst zwart aanbrengen. Dan heb je al een schaduw. Dat word later weer lastiger om te doen.
  15. #15
    Standaard
    Hey Rik,
    zwart is idd aangebracht. Ik gebruik sowieso verf om te kijken als er nergens geen krassen/stukken zijn die putty nodig hebben. Geeft meer op als ik dan de grondverf leg dat het bijvullen nogal meevalt.
    We hebben vandaag nog wat verder gedaan aan de linkertorso. Meer bepaald de typische kruisvorm in de armorplating.
    Werkwijze is relatief simpel. Neem inkt en breng de vorm aan die ik nodig heb (lekker smerig)
    Zet dit over op het donorstukje van de lamel en snij uit (deze maal direct de X-actie genomen)
    Om daarna het stukje te lijmen en te voorzien van een lik verf. Links de onbewerkte torso en rechts de bewerkte. Geef toe, de rechtse ziet er stukken beter uit
    Nadat dit was gedaan vond ik het tijd om even de neussectie wat op te smukken. In de nieuwe pentekening zie je verschillende 'groeven' in de neus. Vond ik nog wel zo mooi.
    Dees werkt een stuk makkelijker, dus zetten we eerst de vorm over op een stukje papier :
    Daarna zoeken we een fijner donorstuk die me toelaat het papier te blijven zien. Ideaal, de verpakking van bijv. kipcurry (maar dan zonder de inhoud uiteraard) dat wat in vorm is gesneden:
    Met pen en meetlat gaan we dan te werk om de nieuwe vorm uit te tekenen en onder het stukje plastiek te plakken. Daarna enkel nog uitsnijden met de X-acto en te kleven.
    en zo ziet het torso er momenteel uit :
    Dat was ie weer voor vandaag. Hope you guys like.
Soortgelijke discussies
  1. Andere - 1/60th Kit Fox
    By Jadefalconguard in forum Afgewerkte projecten zonder bouwverslag
    Reacties: 9
    Laatste bericht: 07-06-09, 14:02
Regels voor berichten
